countrytuner »
https://forums.nicoclub.com/countrytuner-u138796.html
Thu Jul 30, 2009 8:08 pm
hey all, madea breakthrough tonight... got the thing timed properly... DUH!!... oh well. The engine runs now... well kinda. It wont start unless primed with fuel sprayed into the intake, and it only revs up to 4000 RPM... not easily i might add. The throttle is linear up until about quarter throttle, then the more throttle you give it, the crappier it runs and the lower your rpms get (levels out to about 2500 RPM at full throttle with serious missing issues). I've got a number of things to try now. I know its down on compression on cylinders 1, 3, and 4. I dumped a bunch of avgas/premium gas into the tank. It also has a really sloppy idle (idles at around 600 RPM, but will fluctuate between 400 and 800). I havent pulled any codes off of the ecu yet, thats tomrrows job. Anybody have any pointers or ideas on where a good place to start would be? besides obviously pistons and rings with an overbore to get the compression back up. Top end is perfect, valve seats and guides are great. Camshafts and distributor timing is perfect now.
