_shift240 »
https://forums.nicoclub.com/shift240-u65577.html
Thu May 17, 2007 9:39 am
Hi! I have a 1993 240sx running a 1995 ka24de engine, and the #2 cylinder is not firing, and the car is running insanely rich. I haven't done much to the car, it has a custom short-ram intake, hotshot headers, crank pulley, catco cat, and a rs-r ex-mag exhaust.
I have:
-changed the plugs-changed the maf/ maf plug/ re-grounded maf-changed the engine temp sensor (coolant temp. sensor)-switched the spark plug wires to rule out wires as source of problem-added new gas-cleaned all electrical connections, i.e. injector plugs, distributor plugs, sensors, etc.-checked for vacuum leaks/intake leaks
It will start and idle between 600-1100 rpms, usually hovering around 1000, then dropping to 750, then jumping back up.
The next step I've been told is to try to replace the distributor rotor, and possibly the ignition coil.
Any other suggestions? I'm nearly ready to just give up, I'm so frustrated with this car. Thanks
