danshaz82 »
https://forums.nicoclub.com/danshaz82-u67275.html
Thu Sep 27, 2012 6:43 pm
did you strip the bleeder threads? that happened to me twice when i first did my clutch. dont over tighten the bleeder. youll probably have to get a new slave.
whats worked for me is to do it like Ziggy said.
have someone pump the pedal a few times and then hold it down while the bleeder is closed.
then you open the bleeder while the pedal is still pressed. thatll cause the fluid/air to rush out.
close the bleeder while the pedal is still pressed. bring the pedal back up. at this point i like to top off the fluid to make sure i dont run out while bleeding. cause if you do, more air is just going to get back in the line and youll be there all day doing nothing.
then just repeat until you dont see any more bubbles coming out and until the pedal gets stiff. i like to do this a few more times to be absolutely positive theres no air. should be just a solid stream of fluid.
use a clear hose that you can fit on the nipple of the bleeder and run it into some sort of container. that way you can easily see when all the air bubbles are out.
hopefully that helps
also, like kouki munster said, make sure the adjustment rod is properly adjusted. it takes some trial and error. i like to slowly let off the clutch until the car starts to creep forward and make note of where it engages compared to when its all the way pressed and when its all the way returned
