plumcrazydd »
https://forums.nicoclub.com/plumcrazydd-u207327.html
Tue Jul 24, 2012 9:51 pm
1993 240sx SE Coupe KA24DE - 5 Speed manual.
It, after sitting a while after running (Say, a couple of hours) It won't start all the way up. I will crank a little, but not all the way alive. Tried cranking it a bunch of times, and nothing. And as always, after 5minutes or so of trying it will just fire to life on one crank, and run perfect and strong.
NEW:
Starter
Filters and fluids
Clutch and resurfaced flywheel
Breaks all the way around
Tires
2 row radiator
Rebuilt head with Cometic 3 layer steel head gasket
All other gaskets and seals for almost everything else.
Fuel pump
Bunch more new stuff
OLD:
Stock MAF
Stock clutch fan
Alternator (Works just fine)
Help would be appreciated!
Thanks.
