1993 240SX SE: Clutch whining
randomdata
Car: 1993 240sx se
Recently had a new clutch installed.Now when I start the car, I hear this whining noise whenever I have the clutch pressed in. Once I put it in gear and start moving, it stops, until I shift, the noise starts back up until I give it gas again.
The noise stops after I've been driving a few minutes, and it's been making the noise less often over the past week or so.
The clutch seems to operate just fine, but I don't know what to make of the noise, it's not a chatter so much as a whining noise.
Is this normal? Did my mechanic not resurface my flywheel? Could it just be the ridiculous Missouri climate?
Any help would be much appreciated.
randomdata
Car: 1993 240sx se
anyone?
navysnail
allright if it is wining when the clutch is pushed in only, it is most likely your throw out bearing. from what I understand, that is your problem. I am not sure if you are saying it whines when it is out too or not.
randomdata
Car: 1993 240sx se
No, only whines when the clutch pedal is pressed to the floor (or you know, enough to engage it.)
is this something i need to have a shop look at, or is it not a big deal? i don't really mind the noise since it stops after a few minutes of driving, but if its something that will eventually effect drivability, i'll get it checked out.
