1993 240sx running problem?
snuffyus64
Car: 1993 240sx
Hi everyone I have a 240sx hatchback great car very reliable till now.I was driving the other day and it seemed to not accelerating as I am used to. Its also sometimes stalling out. It seems to be really worse when it is a rainy day. I recently gave it a tuneup & filter's change the cap and rotor I got from Nissan. Ran great after tuneup was done.Im fiquiring it might be my mass air flow. I checked into a few prices.Is there a way of testing it with a ohm meter this way I know Im not wasting my money just to still have the problem. Or if anyone might have one laying around I really dont have 200 dollars to waste.Any input on what I can check would be great thanks and keep the 240's rolling....
Snuffy...
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
snuffyus64 wrote:I was driving the other day and it seemed to not accelerating as I am used to. Its also sometimes stalling out. It seems to be really worse when it is a rainy day. I recently gave it a tuneup & filter's change the cap and rotor I got from Nissan. Ran great after tuneup was done.
It sounds here like you fixed your problem with a tuneup, so why did you post?
snuffyus64
Car: 1993 240sx
No I was just mentioning that the car had a recent tuneup so the problem I dont think is with anything like gas filter or cracked cap. It was tuned up about 2 months ago and the problem has just started happening a few days ago.
redsx13
Car: 93 240sx 03 350z
telll us more of what exactly its doing. stalling out and power loss can be hunderds of things. from fuel delivery to electrical to mechanical damage.
redsx13
if it does happen to be your maf. i picked one up recentily for 22 bucks shipped on egay.
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
snuffyus64 wrote:Im fiquiring it might be my mass air flow. I checked into a few prices.Is there a way of testing it with a ohm meter this way I know Im not wasting my money just to still have the problem.
Here's a procedure out of the FSM:
snuffyus64
Car: 1993 240sx
In this testing procedure it shows the Mass Air Flow has 4 wires Terminal 1 on my 1993 240sx doesnt have any wires on it. It only has 3 Wires starting from terminal 2.
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
You're probably starting at the wrong end of the connector. The #1 terminal has a white wire and #2 has a black wire.
out240
If its worse when raining it means moisture is shorting something out. Did you replace distributor rotor? Spark plug wires, could be weak coil. I'll tell you what, I have a ka24de maf from a 91 240 and ignition coil, I'll sell you both for 40$ shipped.... [email protected]
snuffyus64
Car: 1993 240sx
Just to give a update I was able to purchase a used Mass Air Flow Sensor from ebay it took awhile to come but installed it yesterday and that was the problem. Car running great again. Thanks for everyones help.
