tonynalli »
https://forums.nicoclub.com/tonynalli-u14578.html
Mon Nov 13, 2006 9:31 am
^^^wtf???
anyways...here is what you want to do. when you replace the gasket you can puut some grease or a bead of silicone on the valve cover. but keep in mind, if you remove the cover for any reason, you might have to remove and then reapply each time you do it..make sure its dry before you do anything more. then for the half moons just add some grease or a bead of silcone.on them. slowly and carefully lower the cover on the head. once its set properly, start adding the bolts start with the outter four corners(it makes it a little easier to get it aligned. then tighten but not to tight.
