benemorius »
https://forums.nicoclub.com/benemorius-u17066.html
Wed May 31, 2006 4:51 am
It could be either way. Be sure to check that the belt isn't loose. That may not be it, but it's so simple you just have to check it. If you still can't find the noise, have someone turn the wheel while you listen around under the hood. Don't just go replacing parts without knowing for sure what it is.
