1993 240sx...need help replacing my cluster guages lights..how much light bulbs ?!
Syco_Trini
Car: CARZ. GURLZ. CARZ. B-BALL
:help .......im tryin to take apart ma cluster gauge...does n e one have a tutorial or maybe a site that tells me how much bulbs does it takes or how to do the installion......thanx alot holla.......
$yc0-']['ri[]\[]i
What is life without a NISSAN? :D
dorifkin
English?
Anyhow, you need three 194 bulbs and to get to them you need to take off the trim underneath steering wheel and left of the fuse box. then take of the plastic 'box' behind wheel. and then drop the steering wheel through the removal of two 14mm bolts(correct me if wrong). The steering should drop or you will have to pull on the springs to move it. After that unscrew the gauge bezel and gently pull it out. Then unscrew gauge cluster and pull it out. Straightforward after that.
I did'nt go into detail because I believe this has been covered before in other threads.
Sheraz
Mike09
Look at the search button In the top right.(the red one) And look in there
