hondacivicsipower »
https://forums.nicoclub.com/hondacivicsipower-u24737.html
Sun Nov 06, 2005 2:25 pm
Thanks for the reply you are the best.The thing is, when I went to start the car, it started but was hesitating and misfiring profusely. So I shut the car off and checked it out, NO LEAKS.Today I measured the resistance, and above was that I got.The thing is this, when I pulled the injectors, a lot of fuel was still in the fuel rail and i sprayed the fuel rail with intake cleaner to clean out the gunk.I thought it hesitated because more fuel needed to get around, but now when I go and try to start the car, all it does is want to turn over and it won't start.It is confusing the crap out of me, because i have spark, and i have fuel because i hear the fuel pump pump.I even filled up on 93 V POWER for the hell of it, which cost me a penny in itself!Can you explain how to test with that autozone, ECM thing?I am going to REPOSITION the fuel rail because when i put the fuel rail on, the gasket even though there is no leaks, might have hindered one of the injector nozzles causing the misfire, which is what I am hoping.thanks
