rps-13 »
https://forums.nicoclub.com/rps-13-u80668.html
Mon Dec 03, 2007 3:30 am
hi guys i have been serching and searching for a reson why my ka24de isdrowning in gas sometimes when i push the pedal to the fullest normally qhen im going to go on and uphill and i follr it it drowns in gas and it doesnt respond its like a major loss of power (drag) its my daily driver so im in desperate need to fix it. I have changed the following:Fuel lifter( upgraded to 300ZX TT fuel lilter), Sparks NGK, theres no oil in the sparks, theres spark in them so they burn fuel, dont know about the injectors if there good or bad?, not running turbo stock N/A(plannign on going in a few years) dont know if its the fuel pressure regulator, cleaned the throttle plate with carb and achoke cleaner, cleaned the IACV with carb and choke cleaner too, TPS is working, running with out air filter just the housing and a net so debrees dont go into, disconnected all of the emission hoses and plug them all up except for the necesary. Dont know what else it could be ????HELPP!!
