Nismo1182 wrote:Thats not where the PCV valve is, not even close
Bmac, I know on the DOHC KA's its somewhere on the lower intake manifold or something. Im going to look at my spare manifold in a few minutes and find out exactly where its at.
Actually that is exactly where the Positive Crankcase Ventilation (PCV) valve is.
It is basically a small hole with a small hose attached to it.
It is attached directly to the "Breather-Separator"(I think you guys are calling it the "Breather Filter").
The breather-separator is located right next to the valve cover (in front of the oil cap). You should see a small hose connect to the valve cover area from this breather-separator. That is the PCV valve hose.
Click on this picture attachment to see what I mean (it is taken directly from a 1993 240SX service manual)
