cyb3rneticvirushttps://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113"1993 240sx : hitting the brakes car turns off"Wed May 18, 2011 1:19 am
Postby
cyb3rneticvirus »
https://forums.nicoclub.com/cyb3rneticvirus-u145739.htmlWed May 18, 2011 1:19 am
so when i get on the gas then hit the brakes the car shuts off, this started happening after i got into car accident, heres some pics of the damage
no damage to anything else, car started up fine and everything no rad leak ect. i replaced the brake master and booster but it still happens, the car also ideals high about 1.1k Ive checked the vacuum lines all seem fine
Postby
SR86 »
https://forums.nicoclub.com/sr86-u171834.htmlMon Jun 13, 2011 1:15 am
How exactly is it turning off? As in the engine starts to die or loss of power as if someone turned off the key? If its the latter, check your body grounds, there should be one on each side behind each headlight and of course the battery ground that connects to the body and then to the motor.
Postby
airman86 »
https://forums.nicoclub.com/airman86-u126597.htmlMon Jun 27, 2011 9:51 am
The brake booster needs to be able to hold vacuum. 90% of the time when you apply your brakes, your engine will be in vacuum...think about unplugging the brake booster vacuum line and trying to drive the car around. I doubt it'd idle. So it's possible that when you push in your brakes, the brake booster "opens" up.
So try giving it throttle while applying the brakes and see if it stays alive any 'better'.
Postby
cyb3rneticvirus »
https://forums.nicoclub.com/cyb3rneticvirus-u145739.htmlTue Jun 28, 2011 1:44 am
checked the brake booster its fine. when i know theres the problem the car ideals high around 1.3k cold or hot if you disconnect the E.F.I and plug it back in its fine it happens at random times i started overheating with out t-sat (so put in a new t-sat jacked car up ect to bleed) i am running dual altima fans wired to ignition also i am having blue smoke come out of the exhaust the water pump pully feels a lil lose i can wiggle it with the belt on, anything else i might have missed let me know
