slipnfall »
https://forums.nicoclub.com/slipnfall-u4227.html
Sun Feb 05, 2006 3:29 pm
Hun240, Yes you can reset it either by pulling the battery overnight, or using the consult interface we had(car doesn't have to be running). This resets the self learned closed loop maps. You would want to do this for things like, modifying the intake(ie cold-air), or replacing any sensors like O2, MAF, CTS. Unfortunately[I'm pretty sure] it won't help your situation.
Here's a pic of where those two idle valves are. The one that is missing(that squar-ish hole) actually comprises of two valves: the idle adjustment screw, and the ECU-controlled valve. The ECU opens this valve up(by means of pulsing it) to compensate for things such as the air conditioner being on, etc. The valve that you do see installed, adjacent to it(10 o'clock), is the cold start reed valve: the electrical connector applies current to a bi-metal reed, which as it heats up, slowly closes off the airway, thus slowly lowering your idle as you warm up.
I have a lot more pics that would help with vacuum routing if you'de like, just shoot me an email.
I hope someone else can chime in to help you out, I know you really don't want to tear into those valves.
