STi-13Nova »
https://forums.nicoclub.com/sti-13nova-u22419.html
Mon Dec 13, 2004 7:55 am
I have a 1993 240sx fastback coupe. It starts and runs fine sometimes, but then other times it will just crank and not start. It is like intermittent starting I guess you can say. I checked the clutch pedal position switch and it is intacted, I looked at the transmission and all the connections are still intacted, when I get some time I might try to check the ignition relay and start relay. It runs fine when it does finally start but sometimes it just won't start. Can anybody help?
