HSVDrifting »
https://forums.nicoclub.com/hsvdrifting-u59194.html
Mon Mar 26, 2007 4:56 am
I bought this thing basically disassembled. It's sole purpose is to become the turbo drift beater from "H E double hockey sticks" . Anyway, so here's my problem:
First off, we ARE putting a KA24DE into the car. No odd swaps or anything. Anyway, a few friends and I got the motor and transmission in the car, and everything's hooked up (to the best of my knowledge). The motor isn't turning over, so the first diagnostic thing my friends and I think of doing is checking spark. We pulled plug #1 and connected it to wire #1. While we had plug #1 out, we pulled the distributor out and made sure the timing marks matched up. I crank the car...no spark. So we replace the spark plug, and pull the lead that goes from the coil to the distributor out of the distributor (thinking maybe the distributor was bad). We tried to get it to arc to ground...still no spark. Then we pulled the plug out of the coil (the one for the coil is the 2-wire plug right?) and hooked up a test light and tried to start it, only to find that, apparently, the ignition coil isn't even getting power.
Long story short...I've run out of ideas. The last thing I can think of trying is getting an ECU out of a friend's parts car and trying that one. When I was hooking up the starter, I forgot the battery was connected, and when I pulled my hand back after plugging in the plug, I nudged a hot wire into the frame and made a BIG spark (big enough to blow the alternator fuse ). This also happened to be pretty much directly under the ECU.
If anyone has any OTHER ideas, I'd really appreciate it.
Thanks,Collin
Modified by HSVDrifting at 12:36 PM 3/26/2007
