NismoDriver240 »
https://forums.nicoclub.com/nismodriver240-u85415.html
Sat Jun 07, 2008 6:34 pm
I dont seem to know the problem here but here is my diagnostics...
everything is running fine, clutch is holding strong, no slips. i park and go to the mall, go back and start my car no problem, but the clutch feels hella loose. after i start it i go to put it in gear and nothing. blocked out of all gears. i know its still good because when i started it in gear it lurched forward so i turned it off in a hurry.
so now im thinking fluid. i go to a gas station, get some stp dot 3 and fill it up. the little that was left in the reservoir was really gunky and black. I go to town pumping the clutch to hopefully get the fluid running to no avail.
i then notice a spot under my car below the passenger side floor. its leaking the same color fluid as i put in.
now my question is, is it a line that blew off? or something different like the master or master slave cylinder itself? or could it be something different altogether?
i'm getting an engine swap soon, will the swap fix it or will i need something?
Thanks for any and all help NICO I'm so bummed
