1993 240sx brake light issue
S13inBatnRuge
Car: 93 240sx
i noticed just the other day that when i turn my car off and take the keys out of the ignition that my brake lights and third brake light stay on. I tried lifting the pedal up from the bottom side to see if it was stuck but didn't do much good or i didn't have enough power to affect it. after driving it again i also noticed that it stays on while the car is on as well. so no matter what... unless i remove the battery cable the lights are staying on. is it the pedal stuck or some switch thats jammed. any help would be greatly appreciated. thank you
JeromeS13
Car: 2008 Subaru Impreza STI
The little pad is likely broken/missing. Search around and you can find a part number and lots of information about it.
-Jerome
sky20sx
Car: 1993 Nissan 240sx
I actually have the same problem and just picked up the parts today, there are two little "pads" that go on the brake pedal that push on the stop lamp switch and the accs switch (cruise control) when the petal is not being pushed, so when they fall out it causes your brake lights to stay on, and if you are missing both your cruise control won't work either, the parts are only like 2 dollars a piece, I was missing both, you may only be missing the brake light one, but I would just change them both, the nissan dealership I got them from had them in stock. sorry I don't have the part number but they should know what you are talking about.
PantherRacer
Car: 1992 Nissan Skyline R32 RB20DET Sedan
Could someone pick one up for me?my dealership never brought in 180sx's and they're not going to have the part...unless it's on a more common car?blubird/altimamaxima/cefiro or something
JeromeS13
Do a search around here. I know someone has posted the part number before. Just take that to the dealer and they should be able to get it for you, because I'm sure its used in more than just the S chassis.
-Jerome
JeromeS13
Part number: 46512-H0101 RUBBER-STOPPER $0.70 Nissanparts.cc-very good website!!!!
-Jerome
