1993 240sx 5spd Car Jerks getting back on the gas
teknodude
Is it normal for a 240 to jerk when you get back on the gas?
For example , I'm in 2nd gear accelerating, then take my foot of the gas. When i get back on the gas the car jerks once. I can make it jerk multiple times if i just step on the peddle a few times doing 1/4 throttle each time i hit the peddle. I have to step on it really lightly to avoid the jerk. It jerks really bad i do this in 1st gear. Also it doesn't seem to do this in higher gears and speed.
I don't remember my car ever being like this. I'm thinking its the timing, but i don't have a timing light to check it.
Jiggyfry
I;m suffering from the exact same thing, still looking for a solution.
NISTECH
Could possibly be an EGR issue. But may also be a TPS problem. Check both. Easier to do the TPS checks per the FSM first.
zer0c123
Car: 1993 Nissan 240SX Hatch
Me and teknodude worked testing the car today.
We tried backprobing the TPS sensor and got normal readings, which were 5.12 V, 0.47V. I tried unplugging one of the EGR vaccum hoses, but there was no change, can still feel that strong torque. Hope the EGR isn't an issue, because many parts of the egr system were replaced.
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
It's can also be caused by a sloppy drive train i.e. worn motor and transmission mounts along with the rear subframe bushings.
