memole »
https://forums.nicoclub.com/memole-u34058.html
Fri May 05, 2006 4:20 pm
ok then thank you very much.. I was sure I would have to remove the dash and replace the harness or something. good thing I didn't start that project..could the altenator be bad thats why there is a short in it. I didn't unhook the loweer harness fromt he alt I just unhooked it from the fuse block under the hood near the battery,. I cleaned the engine bay with tar and wax remover and a grey scotch brite pad then painted it. hooked everything back uop where I unplugged it and then there was the fuses blowing. I checked all the grounds after I oainted it thniking that maybe aftert paining it they weren't getting a conection but they all show fine (with test light). well thanks again for your help... I guess maybe my lower harness went bad..Chris
