1992 Window motor/regulator
BCC93QT
Car: 1990 Infiniti Q45
1995 Infiniti Q45
Driver side front... Wouldn't care but its MY window. The cable decided to rape itself this weekend. Probably slowly splitting thread after thread until it bunched up. Surprisingly it would go halfway down and back up a couple times. Thought something was in the track but when I removed the door panel this is what i found Looks like the cover to the winding mechanism is spot welded on. Is it worth the effort to run another cable on it or just get a new/used one. Motor itself works. Does anyone have one handy or near one of their local pick n pulls? I would have to source one from a distance away. One of the things I never pulled from my parts cars...
OwnerCS
Did you check the classified area for a part out? I think Mike G will be the most likely to have one in stock.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I know I'm out of drivers side regulators.
Note that they made a design change sometime in the window regulators. I think a brand new regulator is only like $60-$100, so I'd just get a new one versus a used one that you have no idea how good it is.
qship96
Car: 1996 Infiniti Q45
yes,and the design change happened AFTER 1996,as a redesign of the weak part installed in every 90-96Q. My original lasted 60K,its replacement lasted 60K,that ones replacement is still going strong with over 180K on it-so the redesigned part is worth getting!
BCC93QT
1995 Infiniti Q45
Ebay - 36 bucks shipped to my door for a used. + I found some brake cables from my BMX days so I will attempt a fix on my own. Goin under the knife tomorrow so I will update by this weekend when I come out (alive!)
elwesso
2007 BMW M Coupe
Good luck, be sure to post a report!
Brew Q
Car: '92 Q45 91k miles, '05 FX35
past: '99 740i (r.i.p.), '92 Maxima SE, '89 Maxima SE, '04 FX35
Funny, I did a search and find this from just a month ago...
My '92 gave me a Christmas present - front passenger side regulator is busted.
So now I'm on infinitipartsusa.com looking for the part #. I've tried google as well, no luck.
Anyone have the part # handy? or I suppose I can send them an email...hoping to get this sucker ordered and install my rebuilt bose at the same time.
She just turned 88,000 miles the other day :biggrin:
BCC93QT
1995 Infiniti Q45
My part came in the other day. Good ole Ebay. $38 to my door. Haven't put it in yet as its been cold up here in the northeast
SanCarlosQ45
Car: 1994 Q45 144,000
2013 Nissan Xterra Pro-4x
1967 MGB GT Special
I've been using Circle Infiniti's online parts department for the last year. Its much better than Infiniti of Scottsdale ever was/is.
http://www.circleinfiniti.com/Parts.html
The part numbers for my 1994 are:
80721-60U17 : Left hand Regulator at $118
80720-60U17 : Right Hand Regulator at $155
Might want to check that for your 1992, also make sure to enter in your VIN on the left otherwise it will say the part is not available or something like that.
Brew Q
Thanks for the tips guys,
I'll check out circle infiniti - I'm just looking to put a new one in. The ebay ones are used correct? Pulling the door panel tomorrow to assess the damage.
Merry Christmas!
Brew Q
Just checked circleinfiniti and used my VIN... references the original part # and says superceded by the above...at least to 6/94 born on date
Looks like this is the new and improved version. We have a winner!
Brew Q
black plastic tabs on the slide broke on mine... white plastic on the pulley / guide on the top looked okay, but pretty sure it's the original. Just going to replace the whole thing...
and finally putting in my rebuilt Bose at the same time! I knew I was procrastinating for a good reason! :laugh:
