DAUGHTERS240SX »
https://forums.nicoclub.com/daughters240sx-u13073.html
Tue Apr 13, 2004 6:06 am
Here's the deal, While driving in the snow, I thought I was spinning he tires, Turns out the transmission filter was clogged and had no fluid going through the system. I changed the filter and fluid and now it has another issue. It takes about 3 seconds to engage into 1st. If I am at a stop sign with my foot on the brake, you can feel it lurch forward after a coule of second when it engages. If I don't come to a complete stop( slowing around a corner) when it should down shift to first, it slips and then engages hard into first gear. I reviewed other forums and none seemed to answer it completely. I don't want to spend $125 for the high temp flush if it is another problem.
I like my 68 mustang fastback, less problems but more gas.
