I have a 1992 stanza with the manual transmission and it is an absolute ***** to strat when warm! It has NO problems starting when it is cold out or when the car has been sitting for longer than 45 minutes. When it pulls its little hisssy fits, it will start up and idle at about 600rpm for 1 sec and die. turn it off, and try again, and it does the same thing. I get a very faint odor of something funky. Its not coolant and its not gasoline. or at least its not gasoline to the point of fouling sparkplugs. it smells like gasoline, but not entirely. hard to explain.
ANYWAY... when it finally does start, it usually because I have to hold the accelerator all thw way to the floor and hold on the starter for about 10 seconds, then it finally sputters to life. at this rate Ill probably be through a starter in a few more weeks. coolant sensor? clogged fuel filter? what? Any advice?
