Welcome to NICO!!! Nice to have you here.. First off, your friend bought one of the 5 most complex cars ever made..
The suspension problem may well be Dead Accumulators or actuators. They can give you a hard ride. does the car still rise when it's started and lower itself when turned off? Please use the SEARCH button and check post by Texasoil. He is the guru of the "a" model. Also check
http://www.q45asuspension.com/
That Q45a has 9 accumulators that can be recharged for 1200 by texasoil. Dealers charge up to 4000 and more just for replacing them. The car is heavenly when it's working properly and by far a better ride than anything out there, Serious!. I have a 92 Q45a and can tell you that a 92 Q45a will take some duckies to bring back the ride it was intended to have, but not as much and the dealer would have your friend spend.
The power steering can be belts and pulley's or the upper Rack.
Please check into "Chain guides" which can kill a 92Q when they fail. They were made with plastic chain guide and those guides should be replaced by the metal guides.
How many miles does it have? Does she have the maint. records? If not check a dealer and the VIN to get them. See what's been done. A must to assess what "should" be done.
The search button can be your friends biggest friend here at first.
Well that's a beginning anyway.
Don't want to give you too much right off the bat.
red
