1992 Q45a General
mikeestes
Car: Musica, Sports, Reading
As a "newbie" I have really enjoyed reading all of the old threads and am learning quite a bit about my car. Thank you to each and every one of you that have been so dedicated and passionate.
I have read a lot about the BG44K stuff that apparently is to be used to keep injectors clean. It sounds like it is the best stuff for Infiniti Q45's. Where can I get some of that and is it better than Seafoam? Can I get it locally? If not I would be ineterested in getting some from one of the members who dabbles in this stuff whether by telephone or online. When I do get some, how often should it be used? I will anticipate any replies. Bye for now.
Sincerely,
Mike Estes1992 Q45a - 98,000 Miles
PS - What is the best way to maintain the sunroof? From time to time it sticks at about 95%, but will then shut after pulling the metal flap down. Would WD-40 help it glide better?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Mike...
Get your BG44k from Joe... 1888-216-5328... BG stuff is only available to BG dealers only...
ITs much better than seafoam...
As far as the sunroof is concerned, make sure the rails are well lubed...
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
White lithium for the sun roof rails, no Seafoam for the intake of the VH45DE. Call Joe at http://www.everythinginifinti.com on your left.
Nissan also has a nice aerosol can of lithium that Joe can supply (works great for hinges), but be sure to remove excess as all it needs it a thin, clean coat on the rails or the hinges.
