kevindanielk »
https://forums.nicoclub.com/kevindanielk-u42212.html
Tue Dec 13, 2011 10:23 pm
I've seen many Nissan Maxima MAFs fail from cold solder joints, right where the plug pins actually solder into the MAF circuit board. Those bad solder joints start to really expand as the car heats up and when the electrical connection is broken, the vehicle starts to sputter and run like crap, as you try accelerating, since the ecu doesn't get a signal from the MAF to speed up the injector pulses. The engine is flooded with too much air from the open throttle plate and not enough gas. That was the problem with my Q when I first got her. It was sputtering and shutting off on me. My Qs MAF re-soldering was done in 2006 and it's still working to this day.
If you're handy with a soldering iron, I fix them by cutting out the seal on the square plastic cap piece, that's siliconed on above the circuit board, carefully using a single sided blade. I then remove the entire MAF circuit board from it's housing, re-solder those pins back onto the MAF circuit board, re-assemble the MAF, seal up the cap with some silicone and it has always worked. Something to consider doing since I have yet to see a MAF circuit board actually burn out or go bad, aside from those bad solder joints, most likely due to years of engine vibrations.
BTW, this is the first time I've shared this MAF repair info with anyone on any forum so use it wisely here on Nico.
I have seen local guys on Craigslist selling MAFs and requiring your old one as a "core"..... most likely so they can re-solder and resell them over and over. What else would they need a MAF core for :-(}
I hope this info helps you fix your Q.
