mattd1979 wrote:I thought of that but the biggest problem with that which I have found is that when pulling used parts like that, you end up with plastic that is close if not in the same condition as what you already have. The fuel rail harness that I got with the phase II fuel rail is still good. It's most of the other connectors that I need. I remember reading somewhere a good time ago that you could get a replacement MAF connector which included the 3 female terminals, plastic housing, and the plastic insert along with the 3 rubber water proof boots (they slipped over each wire before slipping the wire into the plastic connector housing.) to rebuild the MAF connector. I wondered if they had anything like that for the other connectors as well.
It is hit and miss for sure.. If I see one around here with some good connectors, I'll pull it for you. Usually pick-n-pull where I go just lets me have connectors and small wiring items no charge. The problem is Qs are becoming scarce around here. Sometimes I drive to Memphis just to hit the pull-a-part yard when I see some in inventory. I understand Atlanta GA is Qtopia when it comes to salvage cars.
