1992 Q45 Sony 10-stack problem
Post all your Nissan electronics, car audio and stereo questions here!
garyb
My factory (dealer-installed) Sony 10-stack was working like a champ before my battery went dead and my "buddy" crossed the cables when we jump started my Q45. I replaced the 3-amp fuse on the back of the radio and now everything works fine except the 10-stack. I've got power back to the 10-stack in the trunk but cannot get it to work via the controls in the center console. Any ideas out there before I resort to taking it to a Sony repair shop and having them tear in to it.
Thanks.
agentxx39
Car: music
had the similar situation took out sony bought jvc set at proline in nyc screwed everything up ran cd through tuner and now i hear the radio it over powers the cd its a mess they set the tuner to 88.1 before when cd was on everything else was off tuner cass. now they say tuner must be on for cd to work help
PalmerWMD
Car: 2004 350Z
These questions sound like they would be better served in our stereo section, where I will transfer you guys to.
Fred...:)
garyb
thanks for you help Fred and a hats off to you for a great site!!
Simmsled
Car: TSI GTI - E46 325i
:thinker it sounds like that you have a RF cd changer in the trunk... if that is correct then you might have to reset the proper station on your radio so that you can get the radio frequency feed from your changer. when your radio loses power, the preset stations are usually lost. I bet that is what happened. if you have the correct station on your radio and still nothing, you might want to make sure that you connected the antenna in the back of the radio along with the RF box that comes from your cd changer. usually the radio will not come out of the dash without unplugging the radio antenna and since you had to remove the deck to change the fuse, this could also be a probable cause. give me some feedback and we can go from there
garyb
My CD player is the factory 10-stack so it doesn't go through the FM gig like the aftermarkets. I'm afraid I burned something out when it got jump-started but I was hoping somebody out there might know of a fuse that I missed for that factory 10-stack versus the one on the back of the radio that I already replaced. The radio and cassette work fine.
Simmsled
hrmm... may be fried.
