tangalora »
https://forums.nicoclub.com/tangalora-u10548.html
Tue Oct 08, 2002 12:21 pm
Oh bother. That's what I get for trying to clarify things after the fact.
The photo above doesn't show the shunt connection to the #4 terminal on the white fuel pump control unit harness connector ... it shows the shunt connection to the E terminal on the whte fuel pump control unit harness connector (as described in the previous posts).
Note that the A & F terminal slots have no metal in them (so you really can't mistake the E terminal either way).
If you simply jump this E terminal to ground (with everything but this connector connected), you will bypass the fuel pump control unit altogether, and, if it was shot, then your fuel pump should start working (albeit at constant full 6 amp speed) again. I used my 1990 Q45 for a few weeks in this configuration, until I got around to soldering the fuel pump control unit #4 wire.
The photo below shows the other side of this connection. The photo below shows the white fuel pump control unit connector (integral with the fuel pump control unit itself).
Notice in my case the #4 wire of the fuel pump control unit connector (which connects to the E terminal in the fuel pump control unit harness connector) shows that it saw too much current (probably due to the deteriorating fuel pump which was humming for thousands of miles). It's fried so badly you can see the burn marks.
Interestingly, once I re-soldered and re-inforced that #4 connection to the PC board (and replaced the humming fuel pump), the fpcu worked like a charm and has been for over 10 thousand miles since.
