yeah if i works it would be something that i would be interested in.Q451990 wrote: ↑Wed Nov 18, 2020 9:19 amWe got a 95 Q in at the Pull-a-part yesterday. First time I've seen one there in a couple of years. I pulled the FPCU and opened it. Everything looks good. I can test it in my Q at some point, and let you know for sure if it works.
Does anyone know if the module grounds through the mounts to the car, or can I just plug it in and let it dangle to test it?
im new to this forum and not entirely sure on how to pm on here3Q Jay wrote: ↑Sun Nov 15, 2020 3:06 pmIf you have the time and some solder skills you can probably fix it yourself.
check out your options, always good in my opinion to have a working spare (online/boneyard).
PM me if you want to pay shipping for me to look at it. Assuming all you need is the grounding path upgrade, I'd do that for $40 plus shipping.
I'd still recommend new fuel filter OEM is: NISS #16400-41B1A
You can PM from the user control panel, or there should be a little message icon on the right side of my post at the bottom under my name.
I am definitely interested shoot me an emailQ451990 wrote: ↑Fri Jan 15, 2021 3:44 pmSo I finally got around to checking the FPCU, and it works great. I took it for a drive for about 10 miles, gave it a few WOT runs to be sure it works in "high" mode, and it checks out nicely. I did discover that the module grounds through it's bolts to the chassis. I got around pulling the back seat by using a jumper cable between the FPCU and the webbing that runs between the rear strut towers. 3Q, maybe yours happened to be touching something grounded when you've dangle tested yours in the past.
Anyhow, it's available if anyone wants it.
Yeah seriously! It's what I could find on short notice
For the search archives.....I don't know exactly when in the '95 run the MAF connector cut over. I can verify that my BlacQ (11/94 build) still has the early MAF connector, even though it suffers from other 94-->95 de-contenting (no "bible", no placard on the front center PCV cover, no lower door edge dust seal, no covers over the door holder/stoppers). All of those of course have been retrofitted on mine.....
