Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Sun Dec 13, 2009 12:31 pm
Did you recently start it in colder weather and quickly turn it off? (e.g. shuffling parking spots in the driveway). If so, it's very possible that you flooded the engine. The Q fires all of the injectors simultaneously and puts a lot of fuel in the engine - sort of a reverse choke, but instead of reducing the air in the fuel mixture, it increases the fuel. If you turn the engine off before it reaches operating temperature it's possible to leave a lot of unburnt fuel in the engine and wash the oil off of the piston rings.
Anyhow, try starting the engine with the gas pedal floored. The ECU will recognize this and bypass the heavy hit of fuel. So, floor it and hold the pedal down. Keep the starter engaged until either the engine starts or the battery dies.
Good luck!
Heath
