1992 Q45 ABS noise
NICORPS-Q45
Car: 1992 Infinity Q45
I was wondering if anyone could tell me why my ABS is making grinding-like noises everytime I stop on slick surfaces. Is this a common problem or could it be serious? Thanks all!
911/Q45
Car: 1990 Infiniti Q45
1996 Porsche Turbo
Normal operating sounds.
Q451990
The ABS actuator is on the right side firewall - so the noise is transmitted pretty well to the driver. The job of the ABS is to modulate (pulse) the brakes at a very rapid pace so that the wheels don't lock up. What you're hearing is the pump pulsing the hydraulics rapidly. Perfectly normal as 911/Q45 said.
The clunk you hear and feel in the brake pedal sometimes as you back out of the garage or driveway is the ABS self-test - also normal. I notice mine more on a steep hill.
Heath
squeefoo
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
I've never had my ABS kick in on the street, on wet grass a time or two. It made me wonder for awhile whether it worked. Even though there's plenty of opportunities for panic stops w/these idiots around here.
PS: Change your Brake Fluid to avoid expensive ABS problems. It's cheap insurance.
JT_MONEY_2004
Car: 1990 Q45, Pearl
Q451990 wrote:The clunk you hear and feel in the brake pedal sometimes as you back out of the garage or driveway is the ABS self-test - also normal. I notice mine more on a steep hill.
Heath
That's a relief, i thought that was a problem i'd have to look into. Funny, it wasn't as noticeable on other cars i've owned w/ abs. Nontheless, good info.
