goody90q45 »
https://forums.nicoclub.com/goody90q45-u31761.html
Mon Mar 19, 2007 8:32 am
When I bought my Q the A/C was blowing hot air so I took it to a repair shop. The only problem was the $20 blue relay in the engine compartment fuse box. Maybe you'll be so lucky. You can easily check this yourself by swapping with the blue cruise control relay next to it and see if your AC works and your cruise doesn't.
All the other things you mentioned could also be causing your problem. I know little about AC systems but I'm sure some of the experts will post up some advice. One of our members, Falk, is a neighbor of yours and should be able to tell you a good AC shop in the South Bay without having to drive to San Diego.
BTW- I grew up in Manhattan Beach and then Redondo Beach on Perry Ave. Great area to visit.
Good luck.
