longhaireddwb »
https://forums.nicoclub.com/longhaireddwb-u54623.html
Mon Jan 22, 2007 9:53 am
I've read the book and found that the idle is controlled by the computer getting readings from the engine and air temp sensors. My idle when cold is it won't and when warm its 1400. I feel that the PO messed with the set screw on the intake that the throttle cable gear sits on which is causing the idle to be too high when warm.
My question is, How do I go about testing these two sensors? I know that some of you guru's probably know how. Or how about giving me a web site that has to do with testing sensors? Thanks for your help. Jerry...
