1992 Nissan Skyline GTR coolant leak
kuksees
Car: 1992 Nissan Skyline GTR
Modified by kuksees at 7:55 AM 2/12/2010
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
before i installed my new water pump i filled that hole full of nissan orange rtv and ground a washer to cover the entire hole (from the out side not against the block) this allowed all the rtv to stay in the hole and any water that would leak by would be held in by the washer (sounds rigged but ive done this on every rb water pump ive ever done
kuksees
kuksees
SullivanRacing06 wrote:before i installed my new water pump i filled that hole full of nissan orange rtv and ground a washer to cover the entire hole (from the out side not against the block) this allowed all the rtv to stay in the hole and any water that would leak by would be held in by the washer (sounds rigged but ive done this on every rb water pump ive ever done
I tried doing that, but only after i discovered i had a leak - unfortunately its still leaking a bit. i wish the seller would have told me to do this when assembling the pump.
kuksees
I had to take off the pump again, clean all surfaces and fill the hole with silicon sealant - left overnight before filling cooling system. O.k.now
