these motors (VE30DE) don't have distributor caps; they have individual coils per cylinder. plus there is no belt, only timing chain.PapaTom wrote:Crack in the distributor cap? Timing belt jumped a notch? Only way to check that is to open the front cover, set it at TDC and check the alignment marks on the cam sprockets
hey i know its a long shot but try replacing your ECU. its hard to believe, but these things can go out over time. try getting a used one; i did the same thing to mine when i owned one and it solved alot of problems.sanford7575 wrote:Please Help!!!My 1992 Nissan Maxima SE with 132,000 miles now stalls at stop lights or in stop and go traffic.It also runs rough at low speeds or while idling in traffic, and stumbles badly upon acceleration.There is also a loud sputtering noise while accelerating at low speeds.
if you have the VE motor, yes, you do have a knock sensor and it's located in the middle of your engine. will not cause the above symtoms though. when the knock sensor goes out, it just pulls timing from the motor and dumps xtra fuel making your car run sluggish and you MPG will go way down. will not affect driveability or make your "check engine" light go off.Steve92 wrote: Have the same exact problem with the same year, make and model and pretty much checked all the same things, cept iv had a fuel injector/line flush. Sometimes it happens, other times it runs perfect, i turn on the deforst to avoid the stalling/rough ideling but warmer weather is comming soon ugg.
Only thing iv found here that could casue it and that i havent had checked is the knock sensor(if this year even has one)
hey Chris, are you from the maxima.org website? if so i remember you from along time ago from when i used to make posts of my 94SE. i had the same screen name now as i did then.is Aaron92SE still on the board too or did he disappear as well?Chris92SE wrote:To the OP: it sounds like you have replaced a lot of common problems on your VE. Specifically, cleaning the IACV and throttle body and replacing the coil packs.
If there are no codes, I would start leaning towards one or more injectors.
What kind of plugs did you buy as replacements? Please say NGK. A lot of other plugs, specifically Bosch and Splitfire have given the coil packs trouble, according to a Nissan Tech I talked with.
At one point a couple of years ago, my car ran rough and the fans were acting crazy. I don't drive it very much, so it had been sitting in the garage for a while.
I cleaned the IACV and TB, replacing the gaskets for both. I also had a code for the coolant temp sensor and replaced that. I did them all at the same time, so I think they were not related.
It doesn't really sound like this is your problem, but I thought I would throw it out there.
For others in this thread, the VE has 1) no distributor (coil on plug) and no timing belt (3 timing chains).
