1992 nissan harbody 4X4
nissanluis
Car: 1992 nissan d21 truck 4x4 4 cylinder
Hi...anybody knows where is the vss sensor on my truck...i believe it stopped working because my speedometer is not moving.... any help would be appreciate...THANKS :rotfl
Adverse Effects
Car: 1987 Nissan Navara 2WD 2.4L Z24
Base Standard Cab Pickup 2-Door styleside
5 speed manual
it would be in/on the gbox/transfer output i am guessing
BRubble
nissanluis wrote:Hi...anybody knows where is the vss sensor on my truck...i believe it stopped working because my speedometer is not moving.... any help would be appreciate...THANKS :rotfl
According to the Service Manual for a '93 Hardbody,, the VSS is built into the Speedometer.
Since the Speedometer is Cable Driven,, I'm guessing that there is an issue with the Cable. The manual goe's into replaceing a Broken Cable. The Cable may have came unplugged from the Back of the Cluster Unit.
I don't have any experience with a VSS,, but since the Speedometer is cable driven,, I'm Guessing that the VSS is for the Cruise Control Unit.
Your '92 may be different, so you really need to consult the Service Manual. I think there is a place here that you can download it.
If what I said is incorrect,, somebody please correct me,, as I never had a problem,, with the Speedometer or Odometer on the '93 that I had for 20 years.
Good Luck
