Ramius83 »
https://forums.nicoclub.com/ramius83-u6643.html
Tue Apr 10, 2007 6:26 pm
Well, it sounds like you have a parasitic drain. A parasitic drain is a drain on the battery when the ignition is turned off. An acceptable parasitic drain on any car is 0-30ish milliamps. Anything more is of a concern. You need to go about finding the history of this car, as to what has been done in the past. Has an aftermarket alarm been installed, radio, lights, etc? It may be one of these systems pulling the drain on the battery, or the remnants of one of these systems.
You need to grab yourself a good multi-meter or amp meter. Unhook the positive cable to the battery. Place one of the meter leads on the positive battery post and the other on the positive battery cable that you unhooked. With the doors closed, ignition off, etc, see what the meter is reading. If you have more than 30 millamps of draw, you have a parasitic drain.
Now, to go about finding one is difficult. If you have determined you have a drain, start pulling the fuses located in the cabin compartment one by one, and I repeat, one-by-one. And do the same for the fuses in the engine bay. If you pull a fuse and the parasitic drain number on the meter shoots down to 10ish milliamps or so, then that system related to that fuse is where you need to start looking........Good luck.
