Tims_240 »
https://forums.nicoclub.com/tims-240-u19154.html
Sun Apr 30, 2006 3:13 pm
f you're reading this i appreciate it, atleast someone is trying to help me.First thing i will say is that i took my engine out of my engine bay to have it rebuilt, however the funds didnt come as i expected over the winter, so i put back together the engine (got about to where i was going to start taking the cams out but never did, sooo i didnt get too far) and i painted my engine bay before i put it back in.now onto the real problem. I cannot seem to get any spark out of my igntion system whatsoever. EVERY ground that i can possibly think of, including multiple people that i know who own 240's, can possibly think of are connected. Yes i did say i painted the engine bay, but i sanded down the paint whenever i put a ground back on to ensure good grounds.
the main grounds i can think of off of the top of my head are:1. In the front left to where my old battery used to be, its the one that connects the intake manifold to the frame.2. the two grounds in the back right of the engine bay, one of them connects the Head of the engine to the firewall, and the other one peeps out of a wiring harness that connects to the Head of the engine also, they are side by side.3. there is a ground in the back right of the engine bay under that green thingy not sure what it does but it is connected (its right beside the plug-in for the BMC fluid level)4. there are each a ground directly behind the right and left headlights that come off of a wiring harness.5. there is a ground that connects near the left strut tower (a little below the strut tower bolts about halfway down the engine bay)6. there is a ground that comes out from under the fuse box on the front left side of the engine bay thats about 6 inches long that connects to the engine bay down below (cant see it by standing there)
now im sure i could think of some more if i went to my car and looked, but arent these the MAJOR ones, everytime i search on forums such as freshalloy and zilvia and nico, everyone that has a spark issue that posts, people tell them to check there grounds, well i have a bunch of times.
I have also checked every fuse one the car, i have not missed one i guarantee it! Now as i said before I am not getting any spark, so i should probably tell you what coil and such that i have.
I have a blaster 2 coil, i have the green and black wire going to the negative and the black and red going to the positive, that wiring is right, since i have searched numerous times trying to prove it wrong, everyone says the same thing for that. ok, so.. i have those two wires unplugged from the stock coil (obviously) but everything else is connected perfectly to the stock coil. there is a 3 wire plug, and a 1 wire slide on plug that are connected to the stock coil.
i have a multimeter, and am not too good with it but here is what i did.i got a good ground and then set the multimeter to volts, and put the positive on the positive side of the coil when the key is in the ON position. this gave me a reading of, i think 12.07, and the negative side was exactly the same 12.07, if it was not 12.07 it was extremely close.
Now i thought i should check the ECU to see if i had any codes, so i screwed it into diagnostic mode, and i got 2 readings.. 21 which is Ignition Signal Primary, and i got 12 which is Mass Air Flow Sensor. i have hooked up so many Z32 mafs to 240's for friends and such its ridiculous, so i am a pro at that, so i am not concerned about the mafs not being hooked up right, however the ignition signal primary has me worried.
-tim
