180fan »
https://forums.nicoclub.com/180fan-u3602.html
Thu Aug 03, 2006 9:44 pm
well if it's the starter that could be making the grinding noise, you can pop your starter pretty easily and have it checked.
Did you check the fan clutch or check the fan for any black markings? The fan should be a white plastic, if it's got black markings on it, it's comin from somewhere around that guy. I've seen it cut up the shroud before from the inside.
