znelson »
https://forums.nicoclub.com/znelson-u36902.html
Mon Feb 20, 2006 1:33 am
I think there is an air bubble in my system I just cant get out. I flushed the system twice now and still have the same problem. All started about a week ago, heater blew nice and hot air. That same day as I was driving to work I noticed a ton of steam coming from the resivior on the passenger side of the car. So I pull over and the engine is overheating bad. I let it cool down and limp back to the garage. Upon inspection Im lucky, there was very little coolant left in the system. Anyways, I ran to autozone and replaced the thermostat. The car started leaking coolant from the resivoir side of the firewall, so I figured the heater core was busted and re-routed the heater feedhose back into the block. Problem solved, no leaking anymore. Car was driven all week until tonite with no issues. So I go to put the intake on tonite, and while Im there I decide to try the heater once more. (I fixed the leak by the firewall, guy that did the engine swap didnt tighten the bracket down around the hose that feeds the heater at the firewall) Burped the system with the car jacked up through the radiator cap (btw the burp screw is broke off I, found that out tonite). Coolant flows fine, but I cant get the car to warm up, even if I drive it hard it takes me a good 20mins to get the temp gauge to even approach 1/2way. It actually started blowing colder air when I started to dog the car to see if it would warm. Im completely out of ideas now, any help here? Im about to give up and take the car to get looked at (I have to get someone to tap that burp screw for me anyways)
