burnin240sx »
https://forums.nicoclub.com/burnin240sx-u13121.html
Tue Nov 08, 2005 2:49 pm
I am having a hard time finding the problem with this maxima since it's the first time working on one. Ok here are the symptoms
The car runs fine in park (its auto) but when you take it on a drive is when this very irradiating issue starts. The car will drive fine and then at different rpm's and different throttle points the car will stumble and hunt until you release the TPS and get back on it. If you press more on the gas when the problem starts nothing happens. I have try data login but the connection to the consult disconnects the second the problem starts. And the ECU throws no codes. just a 55.
I have check for bad relays, replaced the TPS, and ECU. I have read about the coolant sensor cause stumbling issues on 96 maxima's and tried that as well. The next thin I am going to try is check ECU grounds. Since it appears that the ECU is turning off for a second and doesn't know where the TPS is until I release it fully.
There is also a recall on the car for the igniter that say's it has driving issues but nothing more. I will be getting the recall fixed soon as another attempt to fix this PITA
Thanks for your help in advance.
