DrLou »
https://forums.nicoclub.com/drlou-u124282.html
Thu Nov 15, 2012 10:04 am
I've just started having a similar problem - though on our '97. And fuel smell is in passenger compartment!
Car has also become - occasionally - hard to start, and Her Wifeliness is getting antsy... All this has started recently, and in conjunction with our dropping temperatures. CEL is not on at the moment, thought it comes and goes - the code is for the knock sensor.
Hope to get under the hood this weekend - meanwhile, what re things to look for? Certainly all fuel lines and junctions should be suspect - this car is 120k or so. But are the injector seals a standard maintenance item? Do I have a risk of a Big Item being bad here, even without the CEL?
( I'm trying to sort through the various causes for these symptoms, given that I'm not seeing a CEL... )
PS - Yes, t.mcginley.jr: your issue sounds like an injector to me.
