1992 maxima ASCD
harleythedog00
hello
Hoping someone can assist me.
92 maxima GXE, Cruise control wont work. Light on the dash engages and I can hear the relay by the battery click on/off as I turn on/off cruise control (if I put my ear to it and someone else depresses button on dash). I was reading some other posts and started troubleshooting the brake pedal switch (automatic). found the switch and tested for +12 on either wire, both were dead. I believe that at least one of these should have +12 and the other should bounce between 0 and +12 depending on the switch open/closed position - ie: brake pedal depressed or not. If both of these are dead, then I have to believe that the ASCD control unit is being signaled that the brake pedal is depressed and hence cruise control wont engage. Is there another relay or fuse controlling the brake pedal switch ? anyone can guide me on where this is sourced from ? anything else I can check ? I have also tested the sterring wheel switches and they are ok. thanks
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
Try changing out the pedal switch, since that is really cheap. If that doesn't fix it, I would guess it would be the relay.
y120k
Car: 1996 Maxima
On my 96, when the cruise control died, the car began preforming badly, it needed a new speedometer head.
Good luck
