blevans3 wrote:......My Q45 hesitates when I accelerate. It usually happens after the car gets warmed up. When it is cold it seems to accelerate fine. It acts almost like it could be an injector issue.....
Welcome to NICO Bill. Leave the coils alone for now. They're not an issue with the 90-95 Q's. You're probably due for plugs but hold off until you do a little more diagnosis.
If you think you have an injector issue might as well ohm test the injectors, cold and hot, to compare readings. It's about a 5 minute job. The connector cluster you're looking for is on the right side of the intake plenum. Ohm test the knock sensors while you're there and get back to us with the readings.
Is the check engine light (CEL) on? Does it light up after about 20 minutes of driving? If yes to either you'll need to pull the ECU codes also.
Where are you located? Someone who lives close with a Consult program can make the diagnosis much easier.
New owners/members should spend some time at
http://q45.org/ reading every article. It may take a couple of days but you'll learn a lot about your Q, i.e. the short life of timing chain guides on the 90-93.
A lot of good articles and resources here on NICO also:
http://www.nicoclub.com/infiniti-technical-articles
