Frank's Generator »
https://forums.nicoclub.com/frank-s-generator-u26355.html
Sat Feb 26, 2005 3:45 pm
Hello All, I have a 92 Infinity Q45 with 100,000 miles on it that has just had 8 new injectors installed for the reasons that 2 were open circuit as measured at each injector with the remainder being replaced due to difficulty in ease of replacement in the future. All the cylinder pressure tests were performed and each cylinder has @160 psi cranking throttle closed. Each independant ignition coil is creating the nominal output energy to fire the plugs, so no question of a failed coil or igniter assembly / wiring harness. 8 New platinum NGK plugs are in the engine and gapped appropriately. The problem is that one cylinder (#6) is creating about 5% of the horsepower it should. After reverifying cylinder pressure, spark plug quality and coil operation as well as igniter I am at wits end.The possibility of an air leak in that particular cylinder was addressed by spraying carb cleaner around ALL potential air leak areas such as lower manifold to cylinder head, lower manifold to upper plenum and finally the base area of the injector. If there is a gasket leak it is not drawing outside air but possibly crankcase? Is that at all possible in this engine / manifold design? Could there be a heavy build up of carbon on the rear of this particular cylinders intake valve as in the BMW / Benz / Caddy engines of yesteryear??? Why a single cylinder? Each of the other cylinders when either the fuel or spark is removed creates a true RPM drop easily noticed.#6 when either fuel or spark is removed there is a VERY slight RPM drop and furtherence of a missfire. What say the assembled masses as I do not relish disassembling this engine to physically see if I am beseiged with carboned up valve seats?
