1992 Infinity convertiable
Ljbelva
Car: 1992 M30 Infinity convertiable
I have an 1992 Infinity convertiable that will not start. It was fine when I parked it in the garage. The security light will not stop flashing and it will not turn over. I have tried locking and unlocking from inside, outside and everything I can think up. It doesn't turn over or make any sound except from the rear it makes a sound like the top wants to go down. Help
darylzero
:welcome: to Nicoclub!!
I would say to start with the battery. If it hasn't been driven in a while then it's probably dead. You can try jumping it or get a new battery.
Ljbelva
Already tried all that.
frapjap
'07 Subaru Legacy
Welcome to NICO!
I'm not familiar with your car, but we do have a possible solution for you.
Here on this forum, we have a comprehensive collection of Factory Service Manuals that are available free to members.
Take a look at the link in my signature and find your make/model and that should get you started on some new options to troubleshoot.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Welcome to NICO.
First thing I would try is to lock and unlock the doors from the outside with the key. The old Q's had an issue with the switches getting worn out and it woudl unlock the door but not disarm the security system. most the time physically unlocking the door with the key would help this.
Next thing I would check is the starter relay. It should be a big blue relay located behind the passenger side headlight (or thereabouts).. You could try jumping the contacts with a paper clip or something on the starter relay connector, and see if the starter goes. If it does, that means you've likely got an issue with the starter relay or with the security system. If it does not, then that means you've probably got a bad starter.
The starter relay is a common failure item on the Q. Sometimes you can bring the starter relays back to life by unplugging them and hitting them against a table top or something. Corrosion can tend to build up inside and foul the contacts, and sometimes you loosen it up enough with a little jarring action.. :)
