PalmerWMD »
https://forums.nicoclub.com/palmerwmd-u108.html
Tue Aug 03, 2004 12:06 am
Also keep in mind that all 90-92 CU shift into first, only on kickdown and then only below a certain speed.
So just because you dont see 1st being used in normal por even moderately aggresive driving ,doesnt indicate a defect.
If you think your TCU doesnt use first, go to a complete stop (or a low speed) and give it complete pedal to the metal.
You should see first gear, if you don,t the problem may be in the transmission itself ,rather than the control units.
Fred..
