I had a similar problem with my 92 sx hatch. Check out the 4 lead wires that attach to the fuel pump assembly. You'll see four small plastic caps and a ground wire on the circular disc where your pump assm. goes into the tank. If your car is idling press and wiggle each of the caps. If your car stalls you've found the power problem- a bad connection, not a bad fuel pump. If thats the prblem email me at
[email protected] and I'll send you the fix
