s13_240_rb20 »
https://forums.nicoclub.com/s13-240-rb20-u87143.html
Tue Mar 10, 2009 8:27 pm
Well, after all my thinking I have decided to switch this automatic to a 5speed setup. I decided that so that I can swap my rb20 into this truck and keep from having to play musical motors.
So I have already pulled a clutch pedal, master cylinder, slave cylinder, and the line connected them from a junkyard 5sp. I will either cut my brake pedal down to size or I will have to go out another day and pull the brake pedal off that junker.
But, anyways, I guess this topic is over now that I have changed my mind. But for anyone who is searching for info:
I have heard that to switch a 5speed KA motor into an auto truck, you have to swap over the fly wheel, torque converter(???), the crank plug(???), etc(???).
--TJ
